batchat25t_105m
Jul 07, 2017Follower
port forwarding missing fields?
so am trying to open ports for world of tanks and am using https://portforward.com/netgear/r6400/ as a source.
now it asks me to fill these two fields
External Starting Port
External Ending Port
but in the netgear ui it only offers this field
External Port Range
so am really confused here and could use some aid on this matter
what do you think i should do ? thanks in advance
Hi batchat25t_105m,
You can uncheck the option that states Use the same port range for Internal port. The link below may also help out.
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi batchat25t_105m,
Dexter
Community Team
Hi batchat25t_105m,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
