wimS
Jun 17, 2018Aspirant
Power (& Internet LED) - Solid Amber
Hi,
For several years I've used my Netgear router as Access Point. This worked great. A few days ago I moved the Netgear to another room, and since then it does not work anymore.
The Power LED remains solid amber. When connecting the Netgear to my ISP's router, the Internet LED is also solid amber.
I looket at the Netgear community, my case seems similar to:
https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/R6300-Power-amp-Internet-LED-Solid-Amber/m-p/1223095#M17393
I tried to upload the firmware as described in:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
but this does not work. I executed the steps until step 8. Indeed, in step 9 the Power LED starts orange, but it stays solid orange forever.
8. Power ON the router while holding down the reset button.
9. Watch the Power LED. It starts with orange color, and then will start flashing orange.
10. Power LED will then turn to flashing green. Count at least 10 flashing green LED and release the reset button.
By the way, I selected "Use the following IP address and set the IP address like below picture." but Default Gateway => 192.168.1.1 seems not to work, since pinging 192.168.1.1 yields "Destination host unreachable".
How can I solve this?
-Wim
Since I was not able to get it working, I went back to the shop, which concluded that the device was broken. So I bought another one.
Thanks for your kind support.
-wim
> [...] I selected "Use the following IP address and set the IP address
The problem is not your computer's "Default gateway" address. If you
set your computer's IP address to "192.168.1.X" (X > 1), then it doesn't
need a gateway to talk to a router at "192.168.1.1" (or to anything else
at a "192.168.1.Y" address).
If the LED indicators are not responding as they should, and you
can't communicate with the router, then I'd worry about the hardware (AC
adapter, router itself).- wcalifas831Prodigy
your router is a R4500 correct? If it is that model it is known that power surges and power outages seem to affect those router's firmware. You can fix that by uploading back the firmware using the tftp method.
- wimSAspirant
I tried to upgrade the firmware with tftp2, but using 192.168.1.1 or 192.168.0.1 does not work. The power LED stays solid amber, and in the tftp2 the progress bar does not fill. I'm afraid I've to buy a new router. Thanks for your advise!
