axe44's avatar
axe44
Follower
Mar 02, 2016
Power Supply
I have 2 power supplies that both say netgear. One is 332-10366-01. I found on this forum that the wnr2000v3 uses this power supply. Does the v4 use the same one or do I use #585-200078-01
  • Retired_Member's avatar
    Retired_Member
    Mar 02, 2016
    Check output VDC and Amps if the same it doesn't matter.
1 Reply
    Retired_Member
