xsdfadad
Sep 22, 2021Aspirant
powerline av 500 / xav5401 | new internet speed but it doesnt work over powerline
Pls I beg you someone help me. two days ago our internet speed doubled and it works fine wifi wise but the internet speed via the powerline is still the old one. I reset the devices uncountable times but I still only get the old internet speed via lan from the powerline adapter.
What speeds are you paying for?
the XAV5401 is an older AV500 powerline device. But powerline is sensitive to interference. Depending on your home and whats causing interference, you might be maxing out your powerline. Or it might just be the limit of that device and upgrading to new powerline devices with higher performance might help.
- xsdfadadAspirant
I now have 100k down, double the size of what I had before (50k down)
- xsdfadadAspirant
I also have a thrid device connected to them, the XWN5001, that should be a newer one I think and that one also doesn't transmit the full 100k
all those devices are AV500 powerline devices.
Powerline is sensitive to interference as well as distance. I'd highly recommend reading a few tested reviews on these devices.
I'd also keep in mind, that they're speeds drop quickly in seperate circuits. The reviews I link to will show tested speeds. 1 test on the same circuit and a couple on different circuits (most homes).
https://www.smallnetbuilder.com/archives/lanwan/lanwan-reviews/31624-homeplug-av-500-adapter-roundup
Another thing to be careful of, if you do upgrade, powerline functions at the speed of the slowest device. So if you upgrade to AV2000 devices but keep your AV500 device connected, you'll get the slower speeds.
