varonica_1
Nov 29, 2019Initiate
problem in accessing default gateway
Hello Friends I am using netgear R6220 Ac 1200. I am very bad in tec. So i have tried to access 192.168.1.1 router login page. Even I visited www.routerlogin.net
I dont know why my IP is 192.168.140.20 but it supposed to be 192.168.1.1
I don't know what the problem is here.
What modem are you connected to?
many times people are running a modem/router combo device and then hooking another router to it. it causes many issues and the one you're having can be one of them.
https://kb.netgear.com/30186/What-is-Double-NAT
If this is the case, you'll either want your combo device in pass through/gateway/modem only mode or you'll want to disable wifi on it and enable access point mode on the netgear device.
> [...] I am very bad in tec. So i have tried to access 192.168.1.1
> router login page. [...]How many people here believe that someone who's "very bad in tec"
would include a hyperlink to
"https://192-168-routerlogin.com/192-168-1-1/", and label it "access
192.168.1.1", as was done in this post?For a remarkably synchronous thread which also provides a cryptic
link to the same site, see:https://community.netgear.com/t5/x/x/m-p/1830060
Must be a coincidence.
