nkj79
Jan 03, 2016Aspirant
Problem setting up WNR614 as Wifi Repeater / Range Extender
Hi, I have a Wifi ADSL2+ Modem (Beetel 450tc1) which I use to connect to my computer. Recently I have purchased a new Netgear WNR614 Wifi Router and want to use as a range extender. I connected the...
- Jan 04, 2016
Ok, disconnect the WNR614 from everything, do a factory reset, then connect a PC to the LAN port and proceed to set it up again.
Retired_Member
Jan 03, 2016If you're going to use a cable between them then you want a ( AP ) access point. Suggest you return it and by a device with AP mode.
Or follow this link
nkj79
Hi searay,
I am using the cable for just to setup the netgear router. At the end I don't want to use cable.
I cannot return that item, so could yo please help me in how to setup the netgear router as a wireless range extender.
- Retired_MemberJan 03, 2016
You cannot use a cable to setup! As soon as you connect them both you cause DHCP problems. Try disabling dhcp first, then connect them. I honestly don't why you even need to connect them both for setup.
- nkj79Jan 03, 2016Aspirant
Thanks searay for your help.
Actually, thats what the user guide says (to connect router to computer with wire.
I will try it do it without wire, with wifi only.
@searay wrote:You cannot use a cable to setup! As soon as you connect them both you cause DHCP problems. Try disabling dhcp first, then connect them. I honestly don't why you even need to connect them both for setup.
I just tried it, but without connecting the router to cabel, I cannot open routerlogin.net.
If you're trying to setup 614 as a repeater I don't understand why you have to connect to the "router" beetel.
I would think the beetle continues on as it always had in the past. I would think ALL changes would be made in the 614 anything other than that doesn't make sense to me.
Good Luck!
