nkj79
Jan 03, 2016Aspirant
Problem setting up WNR614 as Wifi Repeater / Range Extender
Hi, I have a Wifi ADSL2+ Modem (Beetel 450tc1) which I use to connect to my computer. Recently I have purchased a new Netgear WNR614 Wifi Router and want to use as a range extender. I connected the...
- Jan 04, 2016
Ok, disconnect the WNR614 from everything, do a factory reset, then connect a PC to the LAN port and proceed to set it up again.
Retired_Member
Jan 03, 2016You cannot use a cable to setup! As soon as you connect them both you cause DHCP problems. Try disabling dhcp first, then connect them. I honestly don't why you even need to connect them both for setup.
nkj79
Thanks searay for your help.
Actually, thats what the user guide says (to connect router to computer with wire.
I will try it do it without wire, with wifi only.
