nkj79
Jan 03, 2016Aspirant
Problem setting up WNR614 as Wifi Repeater / Range Extender
Hi, I have a Wifi ADSL2+ Modem (Beetel 450tc1) which I use to connect to my computer. Recently I have purchased a new Netgear WNR614 Wifi Router and want to use as a range extender. I connected the...
- Jan 04, 2016
Ok, disconnect the WNR614 from everything, do a factory reset, then connect a PC to the LAN port and proceed to set it up again.
nkj79
Jan 04, 2016Aspirant
Thanks for your support.
I did factory reset and connected the WNR614 to computer with ethernet cable (no other cable plugged in except this). Changed SSID name, password, security settings and channel to same as my Beetel modem and applied it. Here are the settings after that.
Beetel -
IP Address - 192.168.1.1
Subnet - 255.255.255.0
DHCP - 192.168.1.2 to 192.168.1.100
SSID - Neeraj
Channel - 1
Encryption - WEP
WNR614 -
Enable Wireless Repeater Function - ON
Wireless Repeater Address - 192.168.1.105
Base Station MAC Address - Entered Beetel MAC address
LAN TCP/IP Address - 192.168.1.105
DHCP - 192.168.1.106 to 192.168.1.254
SSID - Neeraj
Channel - 1
Encryption - WEP
After this WNR614 interface/settings page is connecting via 192.168.1.105 instead of routerlogin.net.
At this stage, only three lights are glowing in WNR614 - Power, WiFi and Ethernet but Internet light is NOT glowing, it is OFF. I also tried connecting my android phone to Wifi, it is connected to network but no internet found.
I think probably Beetel 450tc1 modem do not support WDS. But can I connect an ethernet wire from my Beetel to WNR614 and can I use that as a wired range extender? What settings should I do for that?
Thanks
TheEther
Jan 04, 2016Guru
Yes, it should work as a wired range extender. I believe the WNR614 doesn't have an Enable AP Mode setting, so you will have to use the old-fashioned method. Disable the Wireless Repeater. You can keep the LAN IP address set to 192.168.1.105.
- Change the Wi-Fi channel so that it is different than the one used by the Beetel. You can keep the SSID and password the same. Devices will automatically join to the strongest channel and jump to the other one as you roam. You can't control when the jump will occur and you might experience a short connection drop during the switch.
Alternatively, you can use a different SSID. This will give you the choice of selecting which Wi-Fi network to connect to. Both Wi-Fi networks will still be connected to the same subnet, so devices can still communicate with each other regardless of which Wi-Fi network they are joined to.
Save your changes. - Disable the DHCP Server. If your computer originally obtained an IP address from the router, it will still probably work for a while, but temporarily switch to a static IP address if you lose connectivity to the WNR614.
- Set the gateway IP address to 192.168.1.1.
- Connect one of the LAN ports of the WNR614 to the Beetel. Leave the Internet port disconnected. It's not used.
- Test Internet connectivity.
- nkj79Jan 04, 2016Aspirant
As soon as I disable Wireless Repeater, I cannot set my WNR614 router IP Address to same subnet 192.168.1.x. It fall back to 10.0.0.x automatically.
While it works fine in 10.0.0.x and I can connect to internet (no matter if I keep same SSID or different, both works) but its not in same network subnet. I want my both routers in same subnet.
It could be some basic stuff, but sorry I am new to networking.
Thanks
- TheEtherJan 04, 2016Guru
- nkj79Jan 05, 2016Aspirant
Thank you for your help.
I am able to setup my new router in same network / subnet and wifi is enabled on both routers (I choose to keep different SSID for both of them).
Also found this blog post with simple steps to how to do this - http://routersetup.blogspot.in/2007/08/connecting-two-routers-wired.html
- TheEtherJan 05, 2016Guru
Thank you for finding that blog. I saw it before but forgot to save the link.
For everyone's benefit, those instructions do NOT apply to newer Netgear routers that have an Enable AP Mode setting, which takes care of disabling the DHCP server. Moreover, the Internet/WAN port is still used to connect to the primary router. This makes the wiring simple and easy to remember and frees up one LAN port.
Enjoy your Access Point.
Hi,
Yes, we can use the WAN/Internet port but when I used that, I was forced to use different subnet, as that was making a LAN to WAN connection instead of LAN to LAN (when we connect lan port to lan port in both routers). But yes, using WAN/Interent port is easier in compare to LAN.
Thank you once again for your support.
BTW, Netgear official support is not good at all. I had a chat with them for over a hour but the support person was enable to resolve my problem.
nkj79 wrote:Hi,
Sorry, I need to clarify.
On your router, you need to use the LAN port when using it as a wired Access Point. If you use the WAN port, you get a different subnet.
On a newer router with an Enable AP Mode setting, you can use the WAN port when using it as an wired Access Point. You WON'T get a different subnet.
