gregpace67
Oct 22, 2022Aspirant
problems using Netgear19 router on starlink network
Good morning, people. I have a problem that I cannot work out... I live in rural NSW, Australia, and have set up a Starlink System on our farm. due to the trees, we have found it necessary to insta...
- Oct 24, 2022
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
Oct 22, 2022Guru - Experienced User
What model NG router do you have? R####, RAX?
- gregpace67Oct 22, 2022AspirantModel is WNDR3700v4
I've also tried a nighthawk AX5, and still the same problem- FURRYe38Oct 22, 2022Guru - Experienced User
Have you tried a Gb lan switch in between there modem and router?
- gregpace67Oct 22, 2022AspirantWhat is a GB Local Area Network switch?
