gregpace67
Oct 22, 2022Aspirant
problems using Netgear19 router on starlink network
Good morning, people. I have a problem that I cannot work out... I live in rural NSW, Australia, and have set up a Starlink System on our farm. due to the trees, we have found it necessary to insta...
- Oct 24, 2022
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
Oct 22, 2022Guru - Experienced User
Have you tried a Gb lan switch in between there modem and router?
gregpace67
What is a GB Local Area Network switch?
- gregpace67Oct 22, 2022AspirantDo you mean use this INSTEAD of the Netgear Router?
- FURRYe38Oct 22, 2022Guru - Experienced User
In between the modem and NG router:
- gregpace67Oct 22, 2022AspirantWhat would be the expected operation of this device to assist in having the internet recognised by my devices attached to the network?
- gregpace67Oct 22, 2022AspirantCould it be anything to do with the AP settings? Should I use a Fixed IP address?
At the moment it is:
IP address 192.168.1.86
IP subnet Mask 255.255.255.0
Gateway IP address 192.168.1.1
Primary DNS 192.168.1.1
there is no secondary DNS address
