gregpace67
Oct 22, 2022Aspirant
problems using Netgear19 router on starlink network
Good morning, people. I have a problem that I cannot work out... I live in rural NSW, Australia, and have set up a Starlink System on our farm. due to the trees, we have found it necessary to insta...
- Oct 24, 2022
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
gregpace67
Do you mean use this INSTEAD of the Netgear Router?
Oct 22, 2022Guru - Experienced User
In between the modem and NG router:
- gregpace67Oct 22, 2022AspirantWhat would be the expected operation of this device to assist in having the internet recognised by my devices attached to the network?
- FURRYe38Oct 24, 2022Guru - Experienced User
Assists in the inter connection between starlink and your router.
It's recommended to contact Startlink for there help and information regarding connecting something up to there services.
- gregpace67Oct 24, 2022AspirantThanks, I've sorted out the problem. It was the sender units that I was using to transmit the signal wirelessly. I was told they were multi-directional, but they're uni-directional. So I swapped them over and the system works! Cheers
