gregpace67
Oct 22, 2022Aspirant
problems using Netgear19 router on starlink network
Good morning, people. I have a problem that I cannot work out... I live in rural NSW, Australia, and have set up a Starlink System on our farm. due to the trees, we have found it necessary to insta...
- Oct 24, 2022
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
Oct 24, 2022Guru - Experienced User
Assists in the inter connection between starlink and your router.
It's recommended to contact Startlink for there help and information regarding connecting something up to there services.
gregpace67
Oct 24, 2022Aspirant
Thanks, I've sorted out the problem. It was the sender units that I was using to transmit the signal wirelessly. I was told they were multi-directional, but they're uni-directional. So I swapped them over and the system works! Cheers
- FURRYe38Oct 24, 2022Guru - Experienced User
Enjoy. 📡
