MSRadell's avatar
MSRadell
QOS settings not staying set on R6400
I'm setting up my R6400 that I just purchased and everything is going to lose except it doesn't appear that the upstream QOS setting I want for IP Phone is staying set. I go through the advanced menu...
  • DexterJB's avatar
    Mar 12, 2016
    Hi @MSRadell,
    Once you have checked the box to Enable Upstream QoS then all the QoS rules will be applied. The radio button indicator will only be highlighted if you select it to edit or delete a certain rule.
    Dexter
    Community Team
