MSRadell
Mar 08, 2016Aspirant
QOS settings not staying set on R6400
I'm setting up my R6400 that I just purchased and everything is going to lose except it doesn't appear that the upstream QOS setting I want for IP Phone is staying set. I go through the advanced menu...
- Mar 12, 2016
Hi @MSRadell,
Once you have checked the box to Enable Upstream QoS then all the QoS rules will be applied. The radio button indicator will only be highlighted if you select it to edit or delete a certain rule.
Dexter
Community Team
DexterJB
Mar 12, 2016NETGEAR Moderator
Hi @MSRadell,
Dexter
Community Team
MSRadell
Mar 12, 2016Aspirant
Thanks, after playing around with it some more that's kind of what I figured but it's nice to get confirmation of that.
