Harbor's avatar
Harbor
Follower
Feb 17, 2018
R6 300V2 MAC Address Filtering Not Working
R6300V2 Router
MAC addresses of all devices have been added to the access list.
The MAC addresses are correct
The 'Turn Access Control On' box is checked.
The 'Apply' button has been pressed
Computers are still not able to connect without a password
Satellite TV devices are not able to connect.
  • Hi Harbor,
    1. What is the firmware version of the router?
    2. What password are the computers being prompted for? WiFi password or router UI admin password?
    3. How are the satellite TV devices connecting to the network? WiFi or Ethernet?
    4. Please makes sure that the computers are set to remember the network when connecting via WiFi so that they won't be prompted for a password every time.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Harbor,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Harbor,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
