KDMThai
Mar 08, 2017Aspirant
R6000 to Virgin Media Super Hub 3 Connection problem.
HI All,
Just taken Virgin Media out on a gamer bundle (yes I know stupid idea :-P) and tried plugging the above into all network ports and can't get a connection. Yet if I plug any device (Laptop / xbox etc etc) directly into the same ports I get connected.
Any thoughts please as the Hub 3.0 from Virgin has to have the worst WiFi ever.
Thanks in advance.
Kevin
Hi KDMThai,
You can check the link below for the steps on how to setup the router in AP mode.
Dexter
Community Team
I'm unclear on what you want to do.
Are you wanting to set up the R6000 as an access point, and use it's wifi instead of the SuperHub? Or something else?
