Vietpride218
Sep 08, 2018Aspirant
R6020 won't work, in particular Genie by the look of it
Recently got second-hand a R6020 router, which I had to then factory reset. Easy enough. After setting up, I was asked if I wanted to update to 1.0.0.34, which I accepted, which has now led to my cur...
- Sep 13, 2018
Actually have now solved it. Was scrounging around and managed to find a forum saying to access the router through "192.168.1.1", which was different from "routerlogin.net". The next button finally loaded and I was able to proceed to setup.
michaelkenward
Sep 09, 2018Guru - Experienced User
Vietpride218 wrote:
Recently got second-hand a R6020 router, which I had to then factory reset. Easy enough. After setting up, I was asked if I wanted to update to 1.0.0.34, which I accepted, which has now led to my current problems.
Where did that come from? The R6020 should opt for the default IP address. If you have another router on your network, or a modem/router, that could explain why you saw that message.
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- antinodeSep 09, 2018Guru
> [...] At first, I was unable to load, [...]
"load" _what_? "unable" is not a useful problem description. It
does not say what you did. It does not say what happened when you did
it. As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] and went to set up everything in Genie, [...]
Which "Genie"? Ever helpful, Netgear uses the name "Genie" for more
than one thing. Netgear routers have a web-browser interface called
"Genie", and Netgear offers application programs for various
computers/pads/phones, which are also called "Genie". I'd stick with
the web-browser interface.
Regarding your pictures, at what am I looking? A Firefox update?
(Your vision must be much better than mine. Copy+paste of the plain
text would be much more helpful than a microscopic picture of the plain
text.)
> [...] I can't even get to the settings through routerlogin.net.
Regarding "can't", see "unable", above.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. If you have problems
when you follow the instructions there, then explain clearly what
you're doing, and what happens when you do it.
> address. [...]
Where did _what_ come from? "1.0.0.34" is a firmware version number,
not an IP address.
> It might help if you told people what the modem is [...]
And it might make no difference at all. Especially if the problem is
simply communicating with the router.- Vietpride218Sep 13, 2018Aspirant
Like I said earlier, all indicator LEDs are solid green.
I was trying to use the web browser interface, like shown in the attached pictures.
The modem is a Moto MG7310 8x4 DOCSIS 3.0 Cable Modem plus N300 Router. I got the Netgear router due to problems with the two-in-one's wifi (ethernet works well on it). Modem's default IP Address is 192.168.0.1, so not sure if the problem is from an identical IP Address between the Moto and the Netgear.
