bgswsi
Nov 27, 2021Aspirant
R6050 AC7050 power light stays amber, no wifi
My R6050 AC7050 has worked the last few years. Now when i turn it on the power light stays amber, and none of the other lights come on. There is no wifi. User manual has no siutation where power light stays amber. Here is what it says for Blinking amber. "The firmware is upgrading, or the Restore Factory Settings button was pressed". But it is not blinking.
I tried pressing Restore Factory Settings button with a paper clip but I don't think there is a button. It is just a hole and when I put paper clip in there, I don't feel it pressing any button.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- bgswsiAspirant
Thanks for the help. Yes I am on windows 10 but I couldn't figure out how to upgrade firmware. The TFTP link on the video page gives me a 403 forbidden access error: http://www.shadowsoftware.net/shadowgameworld/downloads/
So I gave away the R6050 router to someone on craigslist who thought he could get it working. I bought a new Netger R6080 AC1000 router on sale for $40 and am using that instead.
How fast is your Internet connection? If is is above 100 Mbps then the R6080 isn't fast enough.
The R6080 tops out at 100 Mbps (100BASE-Tx) on the WAN/LAN. That is a lot slower than the R6050, which does 1000 Mbps (1000BASE-T).
No idea where that came from. The video link that plemans posted works:
This is the local TFTP link:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
