TnBigDog
Nov 24, 2022Aspirant
R6080 Router Compatibility
Is the R6080 router (which I assume is wifi 5) compatible with a wifi 6 device? Thanks.
No.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.Look at the data sheet.
It isn't compatible with very much, including many newer Internet services.According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.- TnBigDogAspirant
Thanks! Just to clarify--My new laptop has wifi 6 capability. I realize that I cannot get wifi 6 functionality with the R6080 router, but can I still get wifi 5 functionality when using my wifi 6 laptop? In other words, will the router still work? Thank you!
TnBigDog wrote:
... can I still get wifi 5 functionality when using my wifi 6 laptop? In other words, will the router still work? Thank you!
Yes, but you will get hopeless speeds. Nothing will be faster than 100 Mbps. That's the speed limit between your router and the modem.
If your Internet is slower than that, fine.
