cvillelife
May 27, 2023Aspirant
R6080/AC1000 router connection
a couple of days ago i was updating the router after a power surge in my apartment building.. all went fine and the nighthawk app said it was updated then the router lost connection and has not come ...
michaelkenward
May 28, 2023Guru - Experienced User
cvillelife wrote:
a couple of days ago i was updating the router after a power surge in my apartment building.. all went fine and the nighthawk app said it was updated then the router lost connection and has not come back on sense. the power light just flashes green,nothing else.
When you say "updating the router" do you mean the firmware?
"Blinking Green" is a bad sign. As the manual says:
If the Power LED blinks slowly and continuously, the router firmware might be corrupted.
If a standard factory reset fails, there is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Or try TFTP.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Not the easiest thing to do, but TFTP has rescued many a dead device.
Different router, same approach
However, it might not be worth trying to fix your router, especially if your Internet service is anywhere near 100 Mbps.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
cvillelife
May 28, 2023Aspirant
I tried the recovery reset and the power and lan just flashed. I attempted the tftp but no luck, looks like the .img file for the firmware is no good or something.
