cvillelife
May 27, 2023Aspirant
R6080/AC1000 router connection
a couple of days ago i was updating the router after a power surge in my apartment building.. all went fine and the nighthawk app said it was updated then the router lost connection and has not come ...
cvillelife
May 28, 2023Aspirant
I tried the recovery reset and the power and lan just flashed. I attempted the tftp but no luck, looks like the .img file for the firmware is no good or something.
michaelkenward
May 28, 2023Guru - Experienced User
What tells you that? TFTP is tricky. You have to get it right. You should see a series of prompts and messages. They will explain what is happening and where things go wrong.
TFTP is a command-line operation. The router will send some sort of response if TFTP will sees the wrong or broken firmware.
- cvillelifeMay 28, 2023AspirantAfter I drag the .img file into the terminal(I’m on a mac) and hit enter the line after that says no such file or directory
- michaelkenwardMay 28, 2023Guru - Experienced User
cvillelife wrote:
After I drag the .img file into the terminal(I’m on a mac) and hit enter the line after that says no such file or directoryThat's not what you do. Read the instructions for TFTP.
How do I upload firmware to my NETGEAR router using TFTP on Apple macOS? | Answer | NETGEAR Support
Your Mac sees the .img files a a "disk image". It isn't. It is a data file.
You will get some idea of what you need to do from this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
In the case of TFTP, you access the .img file from the command line (see above).
