Suzie-q
Oct 14, 2016Aspirant
R6100 Cannot connect with my Kindle
I disconnected everything a few weeks ago to rearrange home office area and everything works fine but my Kindle. When I enter the network SSID I’m also given 5 options for Security (Open is default)...
- Oct 19, 2016
Hi Suzie-q,
It is possible that the router WiFi is off or not broadcasting. If the wireless light (third from the left) on the front panel of the router is not lit then you can press the WiFi on/off button located on the right side. That's the top button. Make sure that the wireless light is lit blue. Once it is lit, you can check on your Kindle to see if it is picking up the WiFi name. If it is, just connect to it using the WiFi password.
Dexter
Community Team
Suzie-q
Oct 18, 2016Aspirant
Thank you Dexter, for the suggestions but I’m still lost. When signed into www.routerlogin.net the large Wireless icon shows ! WARNING Off. My question now is how do I turn it on? I’ve rebooted both the router and Kindle and still not able to connect (WiFi is ON on the Kindle). I've looked at the settings under the Advanced Tab but they're different than the example link you sent, so I can't compare. They look alright but is there something specific I should look for? Any other suggestions? Thanks much.
Suzanne
DexterJB
Oct 19, 2016NETGEAR Moderator
Hi Suzie-q,
Dexter
Community Team
- Suzie-qOct 20, 2016Aspirant
Well, that was sure easy. The blue light was indeed off. I followed your instructions and in less than a minute the blue light was lit and my Kindle was online. Thank you SO much for your help and time; I really appreciate it.
Suzanne
