SuperAnalogue's avatar
Mar 03, 2018
R6100 no 5G wireless-N
Hello, I have a specific application (Uverse) that requires 5 GHz Wireless-N.   It seems that the R6100 does not actually allow Wireless-N on the 5G band. inSSIDer shows AC-only on the 5G band. Thi...
  • SuperAnalogue's avatar
    Mar 03, 2018
    Just want to post my resolution; the R6100 5G is wireless-N compatible despite how inSSIDer reports, and that was not the issue.
    The issue was IGMP Proxying (U-verse uses multicast). For whatever reason, the R6100 does not make this feature available in AP mode.
    One must disable AP mode, enable IGMP, then reenable AP mode to allow multicast via the WAN. Even though you cannot access the feature, it is still present.
    It would be nice if the R6100 did not disable access to features that are necessary in AP mode, but otherwise I'm happy!
