GerBear's avatar
GerBear
R6100 Printer connection via Ethernet
I just purchased the R6100 Wifi Router and I have a Canon MF4570DN Laser printer with Ethernet connectivity. It would be more convenient for me to connect the printer to the router using Ethernet tha...
  • TheEther's avatar
    TheEther
    Oct 22, 2015
    GerBear
    Does your printer have an Ethernet port? If it does, then plug it into your router and make sure it gets an IP address. Most network printers are, by default, set up to get an IP address automatically. Once connected to the network, most printers will also support Windows printing and should be discoverable from a Windows machine. You will need to make sure you have the appropriate printer driver installed on your machine.
    As always, there are exceptions, so if things aren't working for you, then consult your printer's manual.
