BuckleBomb's avatar
BuckleBomb
R6120 External Access via public IP address
Im trying to set up access some network devices externally on the Netgear R6120.  Ive done this kind of set up a couple times before with no issues and different routers.  So ive set up the port forwarding fine but when i google my public IP address it is different to what the router internet port ip address says
Google Public IP:                        103.55.46.227   (FAKE not actual IP)
Router Internet Port IP Address:100.99.20.149   (FAKE not actual IP)
Why are these different? What is the internet port ip address for?
So i attempted to access using both addresses but neither worked, couldn't ping either of them.  But if im connected to the router network and use the Internet Port IP address i can navigate to my device. Ive tried googling this issue but i cant find anything that seems relevant and must be missing the key words of my problem.
Any suggestions?
Cheers
  • > [...] when i google my public IP address it is different to what the
    > router internet port ip address says [...]
       That's likely your problem, but without the actual (not "FAKE")
    address for the WAN/Internet IP address of the router, it's tough to be
    sure.  Is it a private address?  Plug it into the form at
    "https://whois.arin.net/".
    > [...] must be missing the key words of my problem.
       Try "Carrier-grade NAT"?
          https://en.wikipedia.org/wiki/CGN
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
    > So i attempted to access using both addresses [...]
       From where, the outside world?  You need to talk to the router
    (WAN/Internet interface), but, if it has a non-routed address, then you
    can't reach it (from the outside world) at that address.  And the ISP's
    CGN router knows nothing about your desire for port forwarding.
    > Any suggestions?
       Ask your ISP if you can get a public address?
    > Any suggestions?
    • BuckleBomb's avatar
      BuckleBomb
      Thanks for the info, Carrier Grade NAT looks like what the issue is and matches up with the problem. Thanks for the help, it is greatly appreciated :)
