bhibner
Oct 15, 2021Tutor
R6120 Firmware Problem
How do I update my firmware without wireless internet? My firmware was updating when my router lost power. Now I can't access the interent to complete the firmware installation and the power light is continuously blinking. Can I hook my router up to my laptop that's connected to another network and do it that way? Thanks for any help!
- bhibnerTutor
I've tried to download the firmware file from the Netgear website but keeping get a "the disc image file is corrupted" message when I try to open it.
did you extract it?
You don't actually "open" it to upload it.
You extract it once downloaded and then log into the router and follow the manual install process.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
- bhibnerTutorWhen I click extract, it takes the files to a folder and the only available files are the release notes and a disc image file. Am I doing something wrong?
This smells more serious than you might think.
The blinking is a sign of corrupt firmware.
Not really. Try it and see how far you get. If the standard manual update does not work, start with this:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that fails you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR SupportThis also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same. - swsmitty0909Aspirant
Has anyone else with an R6120 had problems AFTER they updated the latest firmware. I updated it last night and now my home internet is a mess--constant spinning and extremely slow internet loading; tv which had a perfect picture now gets blurry and buffers all the time. Wish I hadn't updated--had no problems before. Is there anything I can do to fix this? I have reset the router several times.
swsmitty0909 you might have better luck starting your own thread versus jumping on someone elses.
