Ruthannocala's avatar
Ruthannocala
R6120 issues
Have to replace 3 yr. old Net Gear, I'll DEFINITELY not be replacing with this brand!
  • plemans's avatar
    Just here to vent or do you want help trying to fix the router?
    This is the community support forum where members of the public try to help out.
    We're not netgear.
    So just trying to figure out what your goal is.
    Thanks
    • I am confused by your reply "we are not netgear".
      The URL of this forum says netgear.com
      Are we then on "unpaidVolunteersHelp.org?
      • plemans's avatar
        If you want to be an a--hole about it sure. Or you could think of it similar to how a stranger pulls over when you're stranded on the road to help. They're not mechanics or paid. They're just people wanting to help others.
