SamUsesNG's avatar
SamUsesNG
Follower
Aug 09, 2021
R6120 powerlight is flashing after bad update
Title says it all, basically I tried to update my router, and accidentally unplugged it while doing that. Now the green power LED is slowly flashing and the router is doing nothing.
  • michaelkenward's avatar
    michaelkenward
    Sadly, unplugging the thing may have done serious damage to the router's firmware. The manual for your device will confirm that the flashing power light you see is a sign of corrupt firmware.
    First see if this gets you anywhere:
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    The chances are low, but you never know, and you won't do any more damage.
    If that fails, then try this:
    • Press reset for 30 seconds
    • Keep pressing reset while removing power
    • Keep pressing reset for another 30 seconds while apply power
    It is a more severe "recovery reset". If that works, and the power light stops flashing, then you may be able to so this:
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    If that fails, then this is the next thing to try:
    How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
    This also explains how to enable TFTP on a Windows PC.
    TFTP isn't the easiest operation – it can take several attenmpst to get the timing right – so if you are forced to use it try a web search for videos that guide you through the process.
    For example:
    Different device, but the approach is the same.
    The good news is that TFTP has rescued many a dead device.
    If that doesn't work, come back for other suggestions.
