oldenkafe
Feb 20, 2023Follower
R6120 Router won't renable wifi during firmware update
I have tried updating the firmware through the route admin page, it says the usual "3 minutes to update firmware", completes the progress bar but after that the router won't enable wi-fi. So the up...
Feb 21, 2023Guru - Experienced User
So you can't connect back to the router?
What are the led's on it doing?
What firmware did you install?
what modem/gateway is it connected to?
Did you try a factory reset?
