mcpax's avatar
mcpax
R6200 caps ethernet wired download speed at 200mbps
I have somewhat recently upgraded my home ISP service to Time Warner's 300mbps service. If I make a wired connection to the ISP's cable modem, I can achieve the advertised 300mbps speed, so I'm getti...
  • mcpax's avatar
    mcpax
    Jul 29, 2016
    I had tried all of those things before posting. (I could make it worse but never better than 200mbps when it should have been 300mbps.) In the last several days, I was plagued with intermittent Internet outages. The R6200 ended up being at fault apparently, as it would not reliably stay connected. I finally replaced it with a R7000 Nighthawk AC1900 and I'm happy to say I'm getting the full 300mbps from the R7000. My problem is solved in that respect, although, I wasn't expecting to have to replace the R6200.
