Kdavis71's avatar
Kdavis71
Follower
Jan 01, 2017
r6200v2 2GHz connection issue
I recently shut off wifi broadcasting for 2 GHz and 5 GHz on my TG1672 all in one from TWC so I can use my netgear router as the sole wifi router. I got it all hooked up and connected my smartphone which works fine off of both the 2 GHz and 5 GHz bands. I connected the router to my HP all in one desktop via ethernet and it worked fine as well that way. The problem is when I go to connect my desktop to the router's 2 GHz band (doesn't support 5 GHz band) and it will connect fine but will have the yellow triangle and say unidentified network, connected, secured, no internet access. I tried rebooting the router and changing the SSID and Password for the network and neither helped.
Can anyone tell me why I can't get internet from the connection on the all in one desktop when it works fine on my phone?
  • Hi Kdavis71,
    1. Please make sure that the driver for the wireless adapter of the desktop is up to date.
    2. Is the wireless adapter able to get a valid IP from the router?
    3. Please make sure the wireless adapter is not set to a static IP. Should be set to DHCP.
    4. Is the desktop simultaneously connected via Ethernet and WiFi?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Kdavis71,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Kdavis71,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
