Obi-Quiet
Dec 22, 2016Aspirant
R6200v2 Guest passphrases don't work
Firmware: V1.0.1.14_1.0.14 A variety of devices can't connect -- but they see the guest access SSIDs just fine. Access to non-guest SSIDs works great, with security and passphrases on. Acc...
- Jan 05, 2017
Hi Obi-Quiet,
Thank you for responding.
I personally have not encountered any posts/thread this issue with this specific model. Checking the release notes for the different firmware versions also do not indicate any fix for this specific issue. However, this is a step that you can try for isolation. You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
