charlesbelisle
Oct 11, 2016Aspirant
R6200v2 Portfowarding for alternative FTP+SFTP
Hi, I tried to create a second FTP + SFTP with other ports than the basic ones that will point to another computer than the basic ports (21 + 22) but I can't figure out why the connexion doesn't ...
- Oct 19, 2016
Hi charlesbelisle,
Thank you for responding.
1. I would like to confirm, it did work with the other computer, right?
2. You can try unchecking the option "Use the same port range for the internal port" and set the same Internal Starting Port and have different external ports for the 2 computers.
Dexter
Community Team
charlesbelisle
Oct 18, 2016Aspirant
Tried to update the firmware. Haven't had any incidences, instead of reseting my Port fowarding already made.
The DMZ doesn't do what I wish : it actually reroute all my existing fowarding rules to a single computer. I wish I could have 2 of them using the same services but on different ports
Anyw clues regarding of that? :)
DexterJB
Oct 19, 2016NETGEAR Moderator
Hi charlesbelisle,
Dexter
Community Team
- charlesbelisleOct 20, 2016Aspirant
The regular ports are working on another computer, yeah. Not the other specified ones as I know.
I'll try the second option to see!
- DexterJBOct 20, 2016NETGEAR Moderator
Hi Dexter,
I feel pretty noob : I finally foudn the reason why it was actually not working. I forgot to uncheck the option "Use the same port range for the internal port", that I guess is the most important point not to forget when you're opening new Posrts numbers..! lol
Pointing all these new ports numbers to the "original" ones worked now.
Thanks for your help!
