nayeemlinkin
Apr 03, 2018Aspirant
R6220- power led blink continiously for 10-12sec
when i start my r6200 power led blinks continiously for 10 sec but everything is okay.. router is working fine... but why power led is blinking? i got this router from warranty... after previous one g...
- Apr 05, 2018
Hi nayeemlinkin,
Welcome to the community!
Does it stay steady afterwards? If yes, that is part of the boot up process.
Dexter
Community Team
nayeemlinkin
Apr 05, 2018Aspirant
yes it stay steady after 10/12 sec... but i have 2 Router, both of them are same model R6220.. one blink in start up another one never blink.... thanks
michaelkenward
Apr 06, 2018Guru - Experienced User
If you have two routers on the same network, you should configure them to avoid conflicts. Usually this means using one router in access point mode.
There is a manual for the R6220 somewhere at the end of this link:
>>> R6220 | Product | Support | NETGEAR <<<
See page 127.
- nayeemlinkinApr 06, 2018Aspirantmy two routers are not in same network.. one i have in my office and one in my home.
