walksonpoo's avatar
walksonpoo
R6220 and 500 MBPS service.....
I have 500 service with my cable provider. I recently got a new router (R6220) and figured it should be able to take the faster speeds i was going to be getting. After getting installed, i was getting about 370 Mbps and 40 up with the router. I thought i would try without the router and ended getting 577 Mbps and 45 up. SO im guessing the router isnt going to be able to handle the speeds?? Or are there settings i could enable/disable to get things to work properly?
Thanks for any help ahead of time.
