USA-mum's avatar
USA-mum
Follower
Apr 21, 2017
R6220 cannot connect to Wii ....
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi USA-mum,
    1. Please add more details regarding your setup.
    2. Is the Wii connected to the router via wired or wireless?
    3. If via wireless, are you connecting to the right WiFi and using the correct password?
    4. Are your other devices working fine?
    Dexter
    Community Team
    • carter91014's avatar
      carter91014
      Hello, I have a Netgear R6220. I am trying to connect wirelessly to a Wii. I have tried numerous things and can't get it to work. I have many other things connected but I have two Wii's not connecting to it. Both give the error (52130)
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi USA-mum,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
