zzy
Aug 19, 2016Aspirant
[R6220] How to modify an existing QoS rule?
I intend to change a QoS rule for a certain device. For example, change the priority from high to low for a device with MAC address as xx:xx:xx:xx:xx:xx. The rule with high priority already exists an...
- Aug 28, 2016
Hi zzy,
Yes, on that same page you will see the QoS Policy names on the list inside the "QoS rules" boxes at the bottom (Queue 1: Highest, Queue 2: High, Queue 3: Normal, Queue 4: Low). You may have to scroll down on the list of items inside the box. Once you see the corresponding QoS Policy name (Pri_MAC_XXXX), you can highlight it and select "Edit" then you can modify the priority level and click Apply.
Dexter
Community Team
DexterJB
Aug 25, 2016NETGEAR Moderator
Hi zzy,
Just select the QoS policy name under the QoS rule box it belongs (Highest, High, Normal, or Low) then select "Edit". You will then be able to change the priority level and then click on Apply.
Dexter
Community Team
- zzyAug 25, 2016Aspirant
Hi DexterJB,
Thanks so much for your reply! But the part I have problem with is "QoS by Device". See the screenshot below (I erased some sensitive information manually):
So there are only two buttons under this section: Add and Reset. (And this section is called "Add Rules"...) If I fill in the rule and click Add, it will be refused because "duplicated MAC address" while Reset simply reset the input fields and does nothing else. If I fill in the fields and click the button Apply at the top, nothing will change after a moment of configuraton.
Do you have any ideas for this?
Thanks!
- DexterJBAug 28, 2016NETGEAR Moderator
Hi zzy,
Dexter
Community Team
