zzy's avatar
zzy
[R6220] How to modify an existing QoS rule?
I intend to change a QoS rule for a certain device. For example, change the priority from high to low for a device with MAC address as xx:xx:xx:xx:xx:xx. The rule with high priority already exists an...
  • DexterJB's avatar
    DexterJB
    Aug 28, 2016
    Hi zzy,
    Yes, on that same page you will see the QoS Policy names on the list inside the "QoS rules" boxes at the bottom (Queue 1: Highest, Queue 2: High, Queue 3: Normal, Queue 4: Low). You may have to scroll down on the list of items inside the box. Once you see the corresponding QoS Policy name (Pri_MAC_XXXX), you can highlight it and select "Edit" then you can modify the priority level and click Apply.
    Dexter
    Community Team
