Akateko
Aug 27, 2015Aspirant
R6220 NetGear WPS blinking
I unchecked the wps pin configuration in the router settings that says enable pin code as described in a recent artice from netgear directly. Although the wps light is still blinking. So is wps going...
ElaineM
Aug 28, 2015NETGEAR Employee Retired
Hello Akateko,
Welcome to the community!
WPS light will still be blinking slowly even if you uncheck the "Enable Router's PIN" and even if you push the WPS button at the back of the router, the PIN will still not work.
Hope this answers your question.
