Akateko
Aug 27, 2015Aspirant
R6220 NetGear WPS blinking
I unchecked the wps pin configuration in the router settings that says enable pin code as described in a recent artice from netgear directly. Although the wps light is still blinking. So is wps going...
Akateko
Aug 28, 2015Aspirant
Thank you for the response. Although is it possible to completely turn off wps?
