epicproblem
Aug 29, 2016Aspirant
R6220 Static Routes bulk import
I have an R6220 running V1.1.0.34_1.0.1 firmware. Is there a way to import a bulk list of static routes to the table in the router database? I have several hundred to create and I don't really wa...
- Retired_MemberAug 29, 2016
The bigger question is can that router even save that many routes? No, there is no way to load.
Retired_Member
Aug 29, 2016The bigger question is can that router even save that many routes? No, there is no way to load.
epicproblem
It's a small amount of text so I'd think there would be enough space in the router memory but if there's no way to bulk load then it doesn't matter.
- Retired_MemberAug 30, 2016
you're welcome,
