brzezinol
Dec 29, 2015Aspirant
R6220 stops routing between WIFI and LAN
Hi, I using netgear R6220 wifi router. i have connected few devices using LAN: TV, Surveilance, and desktop computer, but computer is avalilable only if UPS is switched on. TV is configured using D...
- Retired_MemberDec 29, 2015
Forget static Use address resevations.
Retired_Member
Dec 29, 2015Forget static Use address resevations.
brzezinol
Hm...i will try, DHCP reservations bases on router config...
I will set it today and check.
Thanks for reply.
