brzezinol's avatar
brzezinol
R6220 stops routing between WIFI and LAN
Hi, I using netgear R6220 wifi router. i have connected few devices using LAN: TV, Surveilance, and desktop computer, but computer is avalilable only if UPS is switched on. TV is configured using D...
  • Retired_Member's avatar
    Retired_Member
    Dec 29, 2015
    Forget static Use address resevations.
