rardark
Dec 28, 2023Aspirant
R6220 Supports Site-to-Site VPN?
Hi Everyone,
May I ask if I can use the OpenVpn function in R6220 (together with a asus router) to setup site-to-site Vpn?
Thanks!
"This article applies to":
It appears this model router doesn't support that feature:
https://kb.netgear.com/24267/NETGEAR-Routers-and-UTMs-that-support-VPN
Get the manual for the R6220. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Install OpenVPN Software on Your ComputerYou plan to use an R6220 with an Asus router?
Note that if you put the R6220 into AP mode to avoid double NAT problems, it will not support VPN.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- rardarkAspirant
I would like to setup a site-to-site vpn using R6220 with an Asus router. According to the manual from netgear, I can only use OpenVPN software in a computer to connect R6220 VPN service? Thanks!
You could start by finding a VPN that fills your needs and then investigating how to implement it on your network.
There are so many out there that it isn't possible to come up with definitive advice for a particular router.
