ndima
Oct 09, 2016Aspirant
R6220 VPN not connecting from IOS
R6220 router Firmware Version V1.1.0.34_1.0.1 I'm trying to enable VPN service on R6220 router to use from my IPhone. Created DDNS account, enabled VPN in router setup downloaded conection files....
DexterJB
Oct 11, 2016NETGEAR Moderator
Hi ndima,
OpenVPN for iOS and your corresponding router model is currently not supported. As it stands, the NETGEAR devices that support OpenVPN for iOS are as follows:
R7000
R7800
R8300
R8500
Dexter
Community Team
- ndimaOct 13, 2016Aspirant
According to the User manual OpenVPN is supported in R6220: http://www.downloads.netgear.com/files/GDC/R6220/202-11443-04_R6220_EN_08Jan2016.pdf
How do you know it is not supported?
