sb801's avatar
sb801
R6230 Intermittent / Failing Internet Connection
I have a Netgear ac1200 model R6230 router and, starting last night, I was not able to successfully gain a consistent internet connection through the router.  I had no prior issues since upgrading the firmware a year ago (Version 1.1.0.114).
When I power cycle the router/modem, I can get an internet connection however it eventually fails, usually after about a minute.
The router is connected to a cable modem -- Spectrum internet service.  I am able to connect to the internet with a device directly wire connected to the cable modem.  This connection is strong and stable.  When I route through the router, either wirelessly or via ethernet, it fails.
  • plemans's avatar
    what modem is it?
    have you tried a factory reset and reinstall?
    • sb801's avatar
      sb801
      The modem is DOCSIS 3.1 model EN2251.
      I have not tried a factory reset / reinstall.
      • plemans's avatar
        try the reset. Maybe something was corrupted in it
