drygultch
Sep 02, 2015Tutor
R6250 Drops all Wireless Devices when Access Control List Used!
Help, I have a 6250 lates Firmware installed. I use WPA2/AES no broadcast of SSID. When I setup a ACL(Access Control List) and turn on ACL, everything is good, the devices I specify work, th...
- Sep 02, 2015
Really, so just how many times to you want me to try to reset to factory, 2, 3, 4 times? Apparently you didn't read my last post, reset was tried!
I believe Albert Einstein coined the following: "Insanity: doing the same thing over and over again and expecting different results."
I believe the issue here is that this model and/or firmware version, which is the latest, is infact flawed. My guess is a memory leak.
Thanks for wasting my time, guess it's time to move to new manufacture and product.
netwrks
Sep 02, 2015Master
You should try resetting to factory default after a fw upgrade. Hidding an SSID and MAC ACL arent a security measure. A strong wifi passphrase is.
drygultch
Sep 02, 2015Tutor
Hidding the SSID, MAC Filtering and Strong Password are considered best practices, all of which are deployed, and yes a factory reset was done. I use MAC Filtering not as a security feature, but more as tool to control use from adolesence users in my household. You're not dealing with a novice here, and I would rather have no responses, than quick ill-informed assumptions, which are waste of my time. Thank You!
- netwrksSep 02, 2015Master
We do our best.. Try factory resetting the router. Best practice after a fw upgrade..
- drygultchSep 02, 2015Tutor
