drygultch's avatar
Sep 02, 2015
R6250 Drops all Wireless Devices when Access Control List Used!
Help,     I have a 6250 lates Firmware installed.  I use WPA2/AES no broadcast of SSID.  When I setup a ACL(Access Control List) and turn on ACL, everything is good, the devices I specify work, th...
  • drygultch's avatar
    drygultch
    Sep 02, 2015
    Really, so just how many times to you want me to try to reset to factory, 2, 3, 4 times?  Apparently you didn't read my last post, reset was tried!
    I believe Albert Einstein coined the following: "Insanity: doing the same thing over and over again and expecting different results."
    I believe the issue here is that this model and/or firmware version, which is the latest, is infact flawed. My guess is a memory leak.
    Thanks for wasting my time, guess it's time to move to new manufacture and product.
