SpeedRacerXT
Feb 20, 2018Initiate
R6250 Keeps Dropping the 5G Connection Randomly
Ok, this particular issue has been flogged to death. I even reported it under another post as it seems this forum works about as well as the routers do (seems to have lost my user info....). Anyway, ...
- Feb 20, 2018
Hi SpeedRacerXT,
1. What is the firmware version of the router?
2. Have you tried changing the wireless channel on the 5GHz band?
3. Have you tried resetting the router to factory defaults?
4. Does the 5GHz signal broadcast again without any intervention (power cycle/reboot) from you?
5. Do all the devices that connect to the 5GHz band experience the issue?
Dexter
Community Team
DexterJB
Feb 20, 2018NETGEAR Moderator
Hi SpeedRacerXT,
Dexter
Community Team
DexterJB
Feb 25, 2018NETGEAR Moderator
Hi SpeedRacerXT,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
