Agolz12
Dec 21, 2015Aspirant
R6250 router seems to be slowing down my internet connection
Hi I have a R6250 router with the V1.0.4.2_10.1.10 firmware. I have been noticing a slow internet connection and I think I have the problem pinned down to the router. I plugged in directly to the mod...
- Dec 31, 2015
I got the problem fixed. I got a new router from my internet service provider, they gave me a R6300 and I experienced the exact same problem. I had a tech come out and he hooked up an older Netgear WNDR 3800 router and it solved my issues, I'm now getting the speed I should be through WIFI. I believe it was a problem with the R6000 series, maybe a firmware issue?
Agolz12
Dec 31, 2015Aspirant
